6 | |
2 | |
2 | |
1 | |
1 |
Hi Guys!
My idea is quite simple. What I would like to do is to use DAQmx Read and Write to accept a DVR as input so that I can read/write data directly to memory. This would be really appriciated if it could be applied on a TDMS read/write also (i know that there is a feature like this in TDMS now but it is only applicable on external dvrs).
Pros: Everything
Cons: None
Sincerely,
Andreas
