Simple Idea.
How about including an option for appending the wire type to any given wire Label.
If I label a wire "Enum" the option to append a "<U8>", "<U16>" or "<U32>" would be great.
With Fixed floating point, the benefits are even greater.. "Ring Buffer" would become "Ring Buffer <FXP 20,20>". This would be invaluable when debugginf FPGA code due to unintended data type changes somewhere in the program.
Shane.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
