Hi, it seems LV uses the 1st sunday/monday or the year as week 1, but ISO says the first 4+ day week is week 1. So i started searching for date/time codes on the web and found http://help.gnome.org/users/gthumb/unstable/gthumb-date-formats.html.en
(Since regexp is only partly documented in help i assumed the same was true here)
I found %V which was exactly what i needed, but it didn't work, neither in Format to string or Format date/time to string.
Thus my suggestion is to add/complement with the missing functions from the list:
%C
%D
%e
%E
%F
%g
%G
%h
%k
%l
%O
%P
%r
%R
%s
%T
regards
/Yamaeda
