| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
The String class has an "Enable Wrapping" / "Wrap at word breaks" setting that can be set from the UI or via "EnableWrap" / "Enable Wrapping" property node. Add the same for decoration text class objects, e.g. captions, so that at as much of a long word is displayed in the frame when SizeToText? is false. As it is, a long word near but not at the right edge is automatically wrapped to the next line and thus hidden when the caption height is one line.
