For everybody who deals with a lot of different LabVIEW versions it is difficult to handle the versions.
If you forget to select [save for previous], the code will be recompiled to the newest version.
There is a new feature to select the expected version in the project manager (started with LV2024).
But there is no possibility to select a specific version for the development environment itself (eg in the menue [Tools] - [Options] - ...
