Current behavior:
When saving a new .lvlib inside a .lvproj the save file dialog brings me to the last saved location which is often a different repo.
Desired behavior:
When saving a new .lvlib inside a .lvproj bring me to the root directory where the .lvproj is saved and not the last saved file location. i.e. implement the same behavior as when saving a VI inside a library or a class. This would solve the issue of VIs accidentally being miss-saved outside of the project folder and then getting lost.
