Gum51
Delete function
Hi LabVIEW community!
I would to propose a simple but a very useful idea. You can add an element to the block diagram with right click and Insert. But you can't remove it. The only option is to use Delete on your keyboard.
When you delete an element, it make a wire with loose end lik that:
I would propose:
With Right click on the element Labview proposes you a Delete in the menu and you can properly delete the element without loose end. Like that:
Meilleures salutations.
LV2012
5 Comments
crossrulz
Knight of NI
There's a quick drop for that.  Ctrl+Space (to open QD) and then Ctrl+D.
TomOrr0W
 I think you mean left-click on the element, Ctrl+Space, and then Ctrl+R.
crossrulz
Knight of NI
Well, yeah, you have to have the element to be deleted selected.
Darren
Proven Zealot
You can also drag a selection box around multiple diagram objects, and the Ctrl-Space-Ctrl-R shortcut will remove multiple selected objects and preserve wiring.
Darren
Proven Zealot
