When a project file has been changed, you can view a list of the changes that have been made to the project when closing it. Unfortunately, these changes often lack important details.
For instance, the most common change I make to project files is adding or removing items (even if inadvertently, such as opening a new VI and then immediately closing):
However, the message doesn't indicate which item was added or removed. Usually when I'm looking at this window, I want to know specifically which item was added/removed so that I know whether or not it's important to save the project file or if I accidentally added something that I didn't want in the project (or removed something that I did).
