3 | |
2 | |
2 | |
2 | |
2 |
Inspired by Altenbach's Boolean constant design, I thought of the following....
When we have a SGL or a DBL constant on the block diagram, we have to right click, selece "representation" to find out exactly what type it is. Why not have some indication as to the actual data type which could conveniently act as a menu for changing the data type.
The same thing goes for U8, I8, U16, I16 and so on.
Shane.
