battler.
Dialog settings in Setup.ini to be selectable within Installer Dialog Information
Status: New
Every time I build an installer I have to manually change the following Dialog settings in the SETUP.INI file.
[Dialogs]
UserInfo=0
FeatureInfo1=1
SingleDirectory=1
InstallationType=0
FeatureTree=0
License=1
License2=0
NICertificate=0
ConfirmStart=1
End=1
These settings allow to (a) only show mine or NI's licence agreement. (b) install directly to default directory without prompt etc..
This should not be necessay and these settings should be exposed to the user with the Installer Properties under Dialog Information (see image).
1 Comment
shb
Active Participant
Active Participant
Thanks for these tip! I did not know this.
