This idea is simple. I would like a setting under Tools/Options to disable run when opened. I posted a similar idea for safe mode which was declined as a duplicate because it was very much like Altenbach's sandbox idea.
This is not a duplicate of either. I just want to disable run when opened in my LabVIEW ini file. Maybe it is a duplicate of something I did not find?
Of all the VIs I have written there is not a single one that is set to run when opened. I download a lot of code from the forums and more than once I have run into a VI that was posted with run when opened turned on. That really scares me and each time it happens I feel like I dodged a bullet!
What I will probably do short term is set up a virtual machine for things like opening VIs from the net.
