ouadji
Disable Structure
Status: New
                                              With only 2 subdiagram, the Disable structure should behave in all cases like a flip-flop.
        it's not currently the case and it's annoying
38 Comments
SteenSchmidt
Trusted Enthusiast
@Intaris: Seriously, maybe that's a better suggestion, to remove the "Disable" option of the Disable structure? Adding functionality by removing features. That's lean 🙂
/Steen
CLA, CTA, CLED & LabVIEW Champion
ouadji
Trusted Enthusiast
"the "Disable this case" option should simply be removed"
YES !!!!
It was simply a bad feature. (I'm serious)
ouadji
Trusted Enthusiast
no, it's brave and courageous !  Smiley Happy
(sorry for my bad english, i do my best  Smiley Frustrated  )
altenbach
Knight of NI
There is nothing wrong with forcing the user to go to the desired case before enabling it. Here, all other cases will be automatically disabled and we can look at the new enabled case for visual confirmation that it is the one we actually want. It is a bad idea to automatically enable another case (that we currently don't even see!). No kudos.
I do I think it is incorrect that the VI breaks if all cases are disabled. Code with all cases of a diagram disable structure disabled should be perfectly legal and should not break the VI. This might be a new idea though. This old idea comes close.
ouadji
Trusted Enthusiast
@altenbach:
I totally agree, it is a good idea.
that's also a good way to solve the problem.
Intaris
Proven Zealot
I'm unsure about allowing a structure with outputs to not break code if all cases are disabled.  That seems weird.
ouadji
Trusted Enthusiast
for me, the real solution is : remove the option "Disable this SubDiagram" ....
but the proposal of altenbach seemed to me to be a good alternative. (the least worst)
Manzolli
Active Participant
@Intaris "It still seems like a weird solution to a problem which is essentially that the "Disable this case" option should simply be removed."
Agree! Simple, direct and focus on the positive side. Kudos for you!
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
altenbach
Knight of NI
As long as all outputs have a defined datatype (and they do!), the behavior is not really different to the current case where we have an empty, but enabled case just sitting there doing nothing. Since it has no code by default, why even show it as if there is more to it than meets the eye? The compiler can still maintain tha extra empty case under the hood, but it should not bother the programmer with it. 😉
GregFreeman
Trusted Enthusiast
Good call Shane. Make an idea, I'd vote.
