11 | |
7 | |
3 | |
2 | |
2 |
As the number of classes in a project increases it gets harder and harder to figure out which methods in a class are overridden because you need to scroll up and down to compare the methods listed under each class. A distinctive glyph or icon in the project explorer window would be very helpful. I understand that there are workarounds like creating an override virtual folder and moving the overridden vis inside it or right clicking the class and opening the "VI for Override" window and checking if the vi is listed. However, a distinctive icon would drastically increase code readability.
