Many controls allow you to make scrollbars visible. When a user clicks anywhere within the control, including on the scrollbar, this counts as a Mouse Down. It would be nice if the Mouse Down event would indicate whether the click was on the scrollbar or on the actual clickable area of the control, so you could do different actions based on which it was. Of course, you can usually do manually by checking boundaries of the control against the coordinates of the click, but it seems like a common thing so it would be easier if the check was built in.
