13 | |
11 | |
3 | |
3 | |
2 |
My apologies if this has already been suggested ... I've written many VIs with a While loop that has True wired to the Stop terminal, making it a "Do Once" loop. This is such a common construct (i.e. a VIG) that it might merit its own "structure", something that "looks like" a While loop but has no Stop terminal, no "i" indicator, and is guaranteed to "Run Once". I think having a unique "look" for this common special use of the While loop would be a useful addition. Among other things, it would clearly distinguish "purpose" as different than a While construct.
Bob Schor
