Issues
LabVIEW allowed me to place the Get Process List VI from the DSC module on an RT VI (it shouldn't). When I tried to deploy the VI, I was given a misleading message:
LabVIEW: Failed to load shared library dscProc.dll:ni_lvdsc_process_GetProcessListEnd:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
Those are bad instructions, as it's impossible to install DSC libraries on RT targets either through MAX or FTP.
Suggestions
