8 | |
6 | |
4 | |
3 | |
2 |
Most of the time when I add an event it's a "Value Change" type - the default type. I usually double-click on the Event Source wanting the dialog to accept the selection and close. Since double-click (on event source) is currently ignored, why not treat it as if the "OK" button was pressed?
