DanyAllard
Drag and Drop from a Select a VI... Dialog
Status: Declined
In the past it was possible to Drag and Drop for the Select a VI... Dialog. I don't remember when it was removed but I want it back!
LabVIEW ChampionArchitect
3 Comments
gsussman
Active Participant
If you add the line:
allowDragDropFromFileDlg=true
to your LabVIEW.ini file, the feature will be restored.
Greg Sussman
Sr Business Manager A/D/G BU
DanyAllard
Active Participant
Thank you for the tip
Darren
Proven Zealot
Status changed to: Declined
