13 | |
11 | |
3 | |
3 | |
2 |
I don't use conditional disable structures very often...but when I do, I've always found it a bit annoying that I need to pull up the documentation in order to check what the available options are, and expected string formatting. For symbols with a defined list, why not expose these options through drop-downs?
