It would be cool if you could popup and duplicate a variable in the DSM.
(DSM 2010)
you can "ctrl + left click + drag" to copy objects in the DSM
Hi Joel
I cannot get this to work i.e to copy a Shared Variable in a Process using "CTRL + L-CLICK + DRAG" in DSM 2009SP1 or DSM 2010.
Any ideas?
Cheers
-JG
