When working with classes, you can modify "Access Scope" for VIs either by right-clicking on the VI, or by going to Items Settings section of class properties.
However, in order to change override settings for a VI, you must go to the class properties page. These are not accessible through the right-click menu on VIs.
It'd be quite convenient if these override options were also available through the right-click menu.
