Here we consider a global cluster (first use case) or a function that outputs a cluster and is viewed as icon (second use case).
NOW : GLOBAL VARIABLES POINTING AT TOP LEVEL GLOBAL CONTROLS ONLY
In order to access one item within this global cluster, I have to put on my diagram a global variable pointing to the cluster, and use the "unbundle" function to extract the desired element. Right clicking on the global variable only allows to browse top level controls contained in the global VI (can not directly point at cluster components).
BETTER : GLOBAL VARIABLES THAT CAN IMPLICITELY UNBUNDLE ANY GIVEN GLOBAL CLUSTER COMPONENT
First you would put on your diagram the global variable, pointing to the cluster. Then right click on it and choose in a tree-form menu (alike the menu to choose among properties/methods of an object) that allows to select not only top level controls, but also controls contained within clusters. The global variable would then point directly at the cluster compponent with a name like "Cluster.Component".
Using unbundle function is cumbersome and can be nicely avoided in this situation.
OTHER USE CASE : ICON VIEW VI THAT CAN IMPLICITELY UNBUNDLE ANY GIVEN OUTPUT CLUSTER COMPONENT
For VIs that output clusters (e.g. when the number of outputs is big), the same trick could make it easier to reach specific output cluster contents without the need for an unbundle_by_name operation, at least when the function is viewed as icon.
Sorry, not time for artist views 😉
oz
