DanyAllard
Easier way to insert and delete element in array
Status: Completed
Keyboard shortcuts for inserting into and deleting from arrays were added to LabVIEW 2020 SP1.
I could be easier to insert or delete element from array by only select and hit Insert or Delete on keyboard.
Insead of this:
Select like this:
LabVIEW ChampionArchitect
9 Comments
andre.buurman@carya
Active Participant
In that perspective adding "End" to go to the last element and adding "Home" to go to the first element would also be usefull.
André (CLA, CLED)
JackDunaway
Trusted Enthusiast
Andre, It used to bother me that it was difficult to find the end element of an array, but there is a solution! Right click on the array, and select "Visible Items -> Show Vertical Scrollbar". This works on FP arrays and BD constants. Cheers, Jack
Intaris
Proven Zealot
While we're at it with keys operating on Arrays, how about "PageDn" and PageUp" moving up (Index-wise) and down the visible Array elements by the same number as Array elements are visible.......
Darren
Proven Zealot
If this idea gets implemented, the same gesture should also work on array constants.
Christina_R
Active Participant
Status changed to: Completed
Christina Rogers
fabric
Active Participant
So here are the new shortcuts:
Arrays
Ctrl-Delete Deletes the current element and shifts later elements up.
Ctrl-Shift-Delete Deletes the element before the current element.
Ctrl-Enter Inserts a new element after the current element.
Ctrl-Shift-Enter Inserts a new element before the current element.
Ctrl-PgUp Scrolls the visible elements in an array by one page up.
Ctrl-PgDn Scrolls the visible elements in an array by one page down.
Ctrl-Home Scrolls to the first element in an array.
Ctrl-End Scrolls to the last element in an array.
Tab Moves to the next element if the Auto Tool is on and locked.
Shift-Tab Moves to the previous element if the Auto Tool is on and locked.
It took me a while to find these... Hope this helps someone!
nclark94
Does this work on array constants on the block diagram? I'm having trouble getting the shortcuts to work there. They work on the front panel a-ok.
Nora Clark
Darren
Proven Zealot
I just tried all 10 of the shortcuts that fabric listed on a 1D string array constant in LabVIEW 2024 Q3 and they all worked. Make sure you have Tools > Options > Environment > Lock automatic tool selection CHECKED in order for the Tab and Shift-Tab ones to work.
wiebe@CARYA
Knight of NI
It's tricky and I can't get it working completely. LV24Q3f1
I might be missing something here...
First thing I missed was that the text in the element needs to be selected, not the element. If you select the text (give the element focus I guess) the shortcuts work.
However, there's no way to select text in a Boolean or class (controls, indicators nor constants).
So do these shortcuts work in a Boolean\class array? How?
Why don't the shortcuts work when you select the object instead of the content in the object?
Enum text can be selected, but the shortcuts don't work. In stead, the cursor is added to each element and it keeps coming back...:
