| User | Kudos |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
While debugging my application I became curious that if an easy way finding the error is available how the things will be. Am not sure somebody has proposed it already, am giving my suggestion. The VI can have the option of pausing it when an error occurs anywhere in that VI.
I guess this would help us much better way of debugging an application.
