2 | |
2 | |
2 | |
2 | |
1 |
When you first create a unit test an lvtest file is created next to the VI under test in both the project and on disk.
In order to keep things tidy I like to move my lvtest files under a single tests folder but this move on disk requires you to relink each test to the VI under test, even if moved from within the project.
This is extremely tedious, it should be possible to move them in the project without having to relink every time.
