5 | |
2 | |
2 | |
1 | |
1 |
As is, it is very cumbersome to extract data from waveform/graph clusters.
I would love to see it implemented as in Matlab - you select just one plot, and copy - paste it on another graph, or to a waveform/cluster control, or paste as a constant. But mainly, to another waveform chart/ XY graph!
I would see it as right click on the graph-> copy data (as usual) but copy data is not the last thing, it should open up to have:
Copy All
Copy plot 1
Copy plot 2 etc.
And the same, when pasting into a graph,
Paste data ->
Replace data
Append data to the end
Insert data in beginning
Something like this.
Otherwise, now it's a pain if I want to combine two-three xy graphs from 3 different places on one plot!You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
