Edit >> Create SubVI:  I almost never use this function... but it could be so nice!
Imagine being able to develop code on some diagram, check functionality in line, and quickly generate a subVI.  We're so close with "Create SubVI", but in 7+ years, I've never really used it.
Suggested Tweaks:
1) Use default connector pane (12 terminals)
2) If there are error clusters, wire them to the bottom terminals.
3) If there are error clusters, auto create a case structure and put the code in the No Error case.  Wire the error cluster through the Error case.
4) If there are in and out references (e.g. File In, File Out), wire these to the top terminals.
5) Run Clean Up Diagram.
