Inspired by http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Event-Structure-Dragging-a-Terminal-to-Automatically-S..., it would be nice if we could edit the label of each event case the same way as for in the case structures.
That would allow us to add events by typing - and hey, even auto-completion would be possible
Further, adding/duplicating event cases could be done like in case structures [ Ctrl+(Shift+)Enter ] ...
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
