Epics Support in LabVIEW 2009 DSC Module has increased usability of LabVIEW in EPICS environment very much! But:
1. Import of database file is not really
working!
When creating Epics client IO Server there is this nice feature to <Import> records from database file.
But when doing this there is only on field "VAL" per record created. All the other fields must be added manually though they are defined in the db file.
So please let the import routine pay attention to all the fields that are defined for each record by default and perhaps make it selectable.
This little change shouldn't be a big issue I guess. And it would increase the usability a lot!
2. With DSC it is possible to create on runtime only server types Modbus/Modbus Slave/OPC Client.
Please add Epics Server & Client here.
The goal is to be able DURING RUNTIME to first create sets of Env.Vaiables dynamically (already working with DSC) and then create the network publishing EPICS server.
And of course the other way round: Please let me be able to create an EPICS client by importing a db (dbd) file dynamically and then bind it to dynamically created set of env. variables.
From what I heard from many of our synchrotron customers LabVIEW still has not arrived in this (huge!) EPICS community.
I think it is on a good way with LV 2009 DSC Module. Please let it keep on going!
