13 | |
11 | |
3 | |
3 | |
2 |
When I want to insert a line of text in the Enhanced Icon Editor of an existing VI it usually means I have to overwrite my existing text or cut and paste it.
I.e. If I simply want to go from this:
To this:
It's not that easy and it could be much quicker.
I would like to be able to Right Click (or a similar method) on the Lines Cluster and select "Insert".
This would insert a blank line and move the Line Text and Line Colors accordingly, preserving existing settings thus allowing me to easily edit the above icon's Lines quickly and easily.
