So I'm going through a bunch of VIs and relinking them. So I go to a folder and select say 100 VIs and drop them into a new blank VI. A bunch of dialogs come up telling me VIs are missing and I ignore them all at the moment. Then I go to the block diagram to find which ones are broken to review them one at a time. The only problem is the error list window displays over 100 errors that aren't "SubVI is not Executable". I have all kinds of errors about required inputs not being wired, and for "This VI cannot access the referenced item in private scope". Well I don't really care I'm not trying to run these I'm just trying to find all broken VIs and fix them.
Which got me thinking, can we have a category view of some kind in the Error List Window?
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
