LeifS
Error Ring - Refresh from File
Status: New
Since the Error Ring constant is read from  *--errors.txt files at LV startup and then ignored it is cubersome to add new error codes "while coding", you have to restart LV to get a refresh.
Please give us an option to re-read the contents of the errors.txt files from within LV, maybe from within the Error Ring popup dialog.
/LeifS
4 Comments
PaulG.
Active Participant
Take it one step further. A function key, shortcut or easily found menu selection should send us to an error API or similar workspace. We should be able to manage custom errors seamlessly.
PaulG.
Retired
garrettmarsh
Paul's idea sounds similar to the "Edit Shortcut" screen for Quick Drop Shortcuts, which read/writes the Labview.ini file on the fly. I like it.
Kenny_K
Active Participant
I am experiencing (requesting) the same issue.  Bummer that this has not been implemented yet.
Kenny
AristosQueue (NI)
NI Employee (retired)
The problem with implementing this is thread safety. It's easy to load new error code text files into the system without halting all running VIs -- the files can be loaded and parsed and then merged seamlessly with the existing database. But to take things out, I have to make sure no one is using any strings in the existing database at that exact moment. When I first build the error system (15+ years ago), I avoided adding the locks that would enable this because I thought it would have an impact on performance, but in retrospect, that was probably a stupid premature optimization that is getting in the way of useful functionality. Looking up error strings is rare enough that a mutex lock isn't going to be under contention commonly. I was a much poorer architect back then.
Unfortunately, that long-ago decision does mean that it is a larger project than just adding a button to the dialog to tell LV to re-parse the error code text files. But at some point, it's probably worth re-evaluating.
