I find myself going throught the same mouse stokes over and over to make sure I don't leave DVR IPE errors unhandled. Lots of Merge Errors everywhere. It seems unessecarily tedious. My suggestion would be to do one or more of the following
1. An error terminal on the front of the De-ref and Ref icons that performs a merge error
2. A conditional error terminal that halts execution of the whole IPE for incomming errors
3. A conditonal DVR terminal on the De-ref that does not execute the IPE if a 1556 Error is thrown by the incoming DVR. Also would just pass one 1556 error out of the IPE since they are always both thrown with a bad DVR.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Can-we-have-an-error-in-terminal-on-the-in-place-eleme...
