2 | |
2 | |
2 | |
2 | |
1 |
I sometimes need to create Front Panels that are to be navigated by keyboard alone, which makes the tabbing order quite important. At this stage, I need to ensure my error cluster controls don't get included in the tabbing order list. Given my error cluster controls for any VI that shows its front panel will be moved out of the visible area, I need to ensure the operator cannot tab to them. Therefore, I would like to see error in clusters have their default "Skip this control when tabbing?" property set to True.
I don't think a change to the default property would cause any complications?
This idea is a better idea than my previous Error Cluster disabled by default thanks to tst!
