Currently, there is no access to the User Event references in the Dynamic Events Registry reference. If you have a lot of user events, you either have to bundle the references together into a cluster, or have many wires through the program. My proposal is to add a "Registered User Events" node that allows the programmer to "unbundle" the registered user events references.
Also, the Register for Events node should change the User Event label to the user event name when a user event is wired to it. Finally, there should be some mechanism to access/control the event queue programmatically, perhaps an "invoke node" coupled with the ability to create a reference to an event structure. This invoke node would allow the user to flush the event queue, or perform other operations on it, etc.
