A value change for the autoscale setting of a graph / chart scale is currently not registered. It can only be detected by polling for the scalefit value. The range of detectable events on charts and graphs is currently incomplete. The scale range change event and the autoscale range change event trigger at the same time in unpredictable order. This makes it hard to detect whether a user manually adjusted scale minimum and maximum or adjusted the autoscale settings value in the scale attribute. Different user actions all trigger a scale range change event without any way to discriminate the cause of this event.
