In the current version of DETT (2014) it does not appear possible to trace into VIs in vi.lib and intr.lib. This is unfortunate since we rely on using development packages deployed with VIPM - and these packages are often installed into the LabVIEW folders in one of this sub-folders. Debugging these VIs can be very useful during development and adding custom trace messaging in the application or to the VIPM packages can be cumbersome.
Ideally it should be possible, as an option, to include or exclude these folders.
