Now that coding for LVXCC is finished (get over there and vote before November 6 in the UI Controls category!), back to the Ideas drawing board. ![]()
A common messaging practice involves creating a messaging ref (whether Queue, User Event, or Notifier) from a clustered datatype. The next step involves sending some data along that ref, and the final step is receiving data from the ref:
Above, you can see that the first two messaging types return the entire data cluster on the Receive, thus requiring an 'Unbundle'. I like how the third messaging construct uses the Event Handler Structure to "fan out" the elements on the Event Data Node interface (well, every now and then I'd like access to the top-level data structure on the Event Data Nodes...). All three constructs require fully-formed data structure type information for the Send input.
The interface for these Send and Receive primitives could be simplified, yielding a significant reduction in the BD footprint and an appreciable decrease in layout maintenance.
(Note, also, added a third element on the Dequeue graphic and centered the Enqueue by a pixel
Since the data is already strictly typed in these messaging references, additional type information is not needed in a separate Data Input Terminal.
Below I've illustrated a place I'd love to use this cleaner interface - between a While Loop and a Case Structure. We save 32 pixels - enough space to fit one more primitive into the Case Structure!
Also note: this follows suit for current practices that allow you to "fan out" data structures on the syntax level, such as Property Nodes (with a cameo appearance😞
Discussion questions to duke out in the comments section:
