5 | |
4 | |
3 | |
3 | |
3 |
Just recently ran into an issue with XML namespaces where the LabVIEW implementation just didn't cut it. The AE had R&D confirm this too. The work around, after trolling through the vast sea of .NET XML features & forums, was there. Something this simple shouldn't burn up this much time.
The world around us uses JSON & XML extensively yet the examples are minuscule. It doesn't matter if new examples are .NET, Python or something else but we need to get to solutions quicker.
