Add a new Value (Signaling) value to the source output of events to distinguish between manual user actions (LabVIEW UI) and Value (Signaling) property node writes. I realize the property node is part of the LabVIEW UI, so front panel edits and Value (signaling) write both produce a souce value of 0 (LabVIEW UI), but there still should be a way to distinguish between the two. I often find myself wanting or needing to handle the value change differently based on whether or not vlaue is input manually or whether it originated from a Value (Signaling) write, as when a program is running in manual, or "auto" mode.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
