13 | |
11 | |
3 | |
3 | |
2 |
When programming with large applications, often times you'll have clusters carrying a lot of information. If you hover over the cluster wire and observe Context Help, you might see something like this:
This Context Help window above is rather large and doesn't necessarily make it any easier to see the structure or contents of the cluster. My proposed idea calls for the ability to expand or collapse the cluster contents within the Context Help window, such as this:
What do you think?
