11 | |
10 | |
3 | |
3 | |
2 |
There's a lot you can do with LabVIEW to improve the appearance of the UI. The community has really helped move the LabVIEW UI frontier forward with many wonderful UI palettes and tools to improve UI creation and customization. One key limitation to all of this though is that LabVIEW controls are comprised of parts that are NOT programmatically accessible.
This is a large drawback since it prevents developers from creating dynamic UIs. For example, you cannot really add a good "Dark Mode" feature without designing specifically for dark mode because Frames and other control components are not customizable at runtime.
