Many times there is a need to wire up a chain of sub-VIs that are all from the same toolkit or class. They have a common reference and error cluster flowing through them. It would be great to have function where I could select all the sub-VIs and with one click have them auto-wired. This would dramatically cut down on the number of mouse clicks.
