sletrab
Feature Request: Set the index position of the Legend of a graph
Status: New
You can show the scroll bar of a graph legend. Great if you do not have so much space for the legend. You can even show the index display of the first visible plot. But you can not set this value programmable.
In some cases you must set this value at least to zero. You might know it from a table. You change the table content and it can occurs that your table seems to be empty, because the first visible row is 204. And the new content has only 3 rows. Therefore you change the Top left cell to 0,0 when you change the content.
So this scrollbar is only useable if you can programmable set the Index display value!.
By the way, why can't I change the style of the scroll bar to system style?
Sletrab
