When a file is opened with the file open dialog of LabVIEW, the containing folder can not be moved, even if the file is closed. It is only possible when a file in an other folder is opened.
Not only moving is not possible, but also moving, renaming and ejecting the containing drive.
The folder should definitely not be locked by the dialog after it is closed!
This issue still exists in LabVIEW 2010 SP1.
