Hi all,
I have been using the Labview help a lot, and especilly the feature "Find on the palette",
Then, I was sure the same feature exists on Labview Block Diagram, but it seems not (or precisely not exactly the same)...
meaning, you have a function existing on your block diagram (like below on the picture with the I/O Node)
and you need to add many more functions that you know they are very close to the function you used on the Functions Palette,
So you do a right click and you have an instant view of the Functions palette dedicated to the previously used functions,
But, this windows will blow away, because it is not linked to the behaviour of the Functions palette directly.
And so, you will have to do again and again the procedure to add all the Functions you desired.
