| 377385 Return |
Error 1390 on Dynamic VI Call to Friend Library The error is returned when two Community scoped LabVIEW Libraries are Friends to each other, and one Library performs a dynamic call to a VI in the other Library. Workaround: Change the dynamic call to a static call, or change the scope to Public on the Library containing the callee VI.
| 366921 Return |
Community scoped VIs within classes in a LabVIEW library will break a packed project library and cause Error 3 N/A Workaround: N/A
Having a set resolution date would be nice. Getting these fixed in the near future (LV2014 or 2014 SP1) would be awesome!
These bugs are being tracked in the CAR database, not in the Idea Exchange.
