5 | |
3 | |
3 | |
3 | |
3 |
Good day forum
Upon wiring an error wire to the termination terminal for timed loop, deletion of the error wire will not necessitate the connection of the terminal.
A fix will be appreciated. Thanks in advanced.
Regards
CY
Available in LabVIEW NXG. See the idea discussion thread for more information about Timed Loop behavior in LabVIEW NXG.
