cy...
Fix Timed Loop termination terminal
Status: Completed
Available in LabVIEW NXG. See the idea discussion thread for more information about Timed Loop behavior in LabVIEW NXG.
Good day forum
Upon wiring an error wire to the termination terminal for timed loop, deletion of the error wire will not necessitate the connection of the terminal.
A fix will be appreciated. Thanks in advanced.
Regards
CY
CY (expired CLAD)
19 Comments
Intaris
Proven Zealot
Well I'll be...... Heart
The only question remaining is if I saw that previously and had forgotten it in the meantime, thus leading to that suggestion...... Smiley Frustrated
cy...
Active Participant
well I'll be .... too
I am quite positive that this is new to me, but it is an improvement. hope the R&D will do something to address this soon... not in the NXG of course 🙂
thanks AristoQueue
CY (expired CLAD)
Darren
Proven Zealot
There are no plans to change the Timed Loop in LabVIEW to match the implementation in LabVIEW NXG. I am closing this idea as Complete in LabVIEW NXG.
Darren
Proven Zealot
Status changed to: Completed
cy...
Active Participant
it is good to know that there were changes made, it is sad cause it is only for NXG, LV itself is no longer in focus
if transition is inevitable, please make it seamless and snappy. 2 years already and cRIOs still nowhere in sight. 2 cents.
*p/s: please don't inherit LV's version dependence in NXG
CY (expired CLAD)
crossrulz
Knight of NI
I don't know why people are still surprised when they figure out that LabVIEW 20XX will not get all of the features already done in NXG.  NI has not been shy at stating that NXG will completely replace LabVIEW 20XX eventually.  But we still have many years before that will happen because feature parity needs to be reached first.  And NXG was a complete rewrite of the IDE in order to be able to handle many of these features that people have been begging for.
GCentral
AristosQueue (NI)
NI Employee (retired)
LV 20xx is still very much in focus and will be getting new features and bug fixes for the next several years, including some features that won't immediately be in LabVIEW NXG. LabVIEW NXG has 30+ years of LV 20xx code to catch up with. It's going to take a while. But we are not leaving LabVIEW 20xx to wither in the meantime. Channel wires, malleable VIs, lots of new stuff on the horizon. We are making decisions about what to do in 20xx and what to do in NXG on a case by case basis.
wiebe@CARYA
Knight of NI
Naturally big changes will trigger resistance. Some thinks would need to change to make NXG useful for me (the tunnel vision to the code). But at the speed NXG is improving, it will be (very) good within a few years.
Am I wrong thinking that parts developed for NXG are actually used in CG (and vice versa)? Maybe not as API, but as shared code? Or at least the algorithms?
AristosQueue (NI)
The compiler and runtime engine are shared between the two platforms. Nothing else is common. They don't even share a language base: One is written in C++. The other is written in C#.
