13 | |
11 | |
3 | |
3 | |
3 |
The System Numerics are driving me crazy! My wants are simple, a radix display and increment/decrement controls.
System Spinner = Increment/decrement but no radix. Why the property page gives you the option is a mystery.
System Numeric = Radix but no increment/decrement. Argh.
When you have the default style set to System, the created controls leave you in no-mans land. A system spinner with invisible spinners. If you wanted a spinner, you have to make them visible. If you wanted a numeric with radix you have to replace, and then resize. It seems nobody is happy.
I seem to want the numeric more often than the spinner myself, I would be happier if it was the default.
Bugs: there are issues with the property pages versus right-click menu settings (LV9 hopefully fixed). Besides giving you false hope with the radix display of the spinner, the checkboxes for increment/decrement do not always reflect the current state. It often shows up unchecked even when they are visible. Just adds to the fun.
tl;dr : Make a single system numeric with both radix display and increment/decrement buttons.
